I have a new set of roller chain tighteners from RR ,look like they will work great. I have a question on the placement, top or bottom of chain. Should they be placed different for the front and back chains? Does any one have pictures after they have placed them? Any words of wisdom before I stare the replacement.
Max II chain adjusters from RR
You will want to place them in the same position as the stock tensionors. The front ones will be on top of the chain and the rear ones will be on the bottom. The Max II is driven from the jackshaft to the center axles. This pulls the front chains tight on the bottom and it pulls the rear chains tight on the top so the tensionors will need to be on the opposite side to adjust the slack.
Originally posted by Cdwamsley View PostI have a new set of roller chain tighteners from RR ,look like they will work great. I have a question on the placement, top or bottom of chain. Should they be placed different for the front and back chains? Does any one have pictures after they have placed them? Any words of wisdom before I stare the replacement.
Those are probably my favorite product from Richard's Relics. The stock Max II chain adjusters are crap and in need of an update. Richard's adjusters hold tight and are easier to install than the factory adjusters. Front adjusters go on top of the chain, rear adjusters go below the chain. That should be how your factory adjusters were but just in case someone already messed those up, be sure to install your new ones correctly.Everybody dies, but not everybody lives.
