Thanks, sorry I'm so dumb but, I'm fairly new to all this Max stuff. =) trying to follow along.
let's talk bearings
At some point R.I. started using a smaller bearing on the inner end of the axles, and a bolt for axle retention much the same as Argo does. I bought a replacement axle around Christmas time and it was turned down on the inner end. I still used my 1 1/4" bearing (it was new) by putting a spacer in next to the frame. This pushed the bearing out to the part of the axle that was still full diameter.
K in bearing talk LOL here are the damn Muscateer Axle bearings I've been searching for OMG what a PITA!
here two angles same bearings LOL Notice the internal O ring and the external double lip seal..
lil closer inner o ring groove
and again
These machines require a sealed setup like this and I'm struggling in Canada to locate the damn things, 12 in total.
I can get single seal with that outer seal but no inner O ring...but double seal NOPE
Anyone able to assist with locating?MUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
Like Drew said, Buffalo Bearing sells them with the collars. Tell Greg or any of the helpful folks over there that you're with 6X6World and they'll take good care of you. (716) 874-1720.Originally posted by Sherman802 View PostI have always bought them from RR for 25 a piece"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
hey guys thanx a lot. max IV can be a pain in the but every time I change an outer bearing I wind up replacing both of them because the axle is already out. clean the tub , strip caulk , spend an hour driving the bearings off the axle , seal the bearing retainers. All the time it takes me to do it if I save a little extra cash makes me feel a lot better.
