Axle Torque
I have my propeller design complete!!! You guys are going to love this when I'm done with it. Now I need to order my parts! I'm going to be using a 12 volt electric clutch and need to know how much torque is on my axle. I have an 18HP Briggs installed. I looked through the manual and it doesn't specify a torque value. Would appreciate some help please.
Make sure you calculate the gear ratio for your specific application. You can use 6.25 for the T20 but count the teeth on your sprockets and see what the actual gear ratio is for your Max. Also look up what kind of drive ratio you have for your specific CVTs. I would hate for you to invest a good chunk of change only to realize the numbers I threw out were not true for your case, causing it to just be a waste of money.
