In the process of doing a conversion from inner bushings to inner bearings on my 97 max II that has solid pinned axles. Where I ride is mostly sandy creek beds which tends to get a lot of water inside the machine from splashing and such. The sand seems to be the main culprit of tearing up my inner bushings on a monthly basis i'm assuming. tried greasing the bushing and everything with no luck.
So the question is. Does anyone have a source for the 2 bolt inner bearing flanges and bearings for 1 1/4" axles. Whether they are 72mm or 62mm doesnt matter to me. Going to be boxing frame in shortly and need flanges for bolt spacing and such. Thanks in advance
