My wife and I went to spray down the chains, squirt grease in the bearings, and change the engine oil this evening.
Spraying the chains was the easy part. The problems began when I could not find the inner berring zerks to the rear axle. Engine is on the way. Fishing the hand under there to feel for the zerks is more than differcult.
How do you guys find these zerks? Is there an easy way?
We also could not find the drsin bolt to the Kohler Command 25. I did find a red plastic thread protector fastened on some sort of thing I assume is a drain? This plastic cap has a FX 5 on it. What is this? Is there an easy way to drain the oil?
Thank you.
Thank you.
