I just bought my first Max IV and am loving driving it all over my 14 acres in VA. It does make some occasional weird clunking noises that sound related to the chains/sprockets/bearings. The transmission doesn't make any noise that I can tell. I've greased all the outboard zerk fittings and lubed the chains which are new. Being a machine from the late 90's I'd like to go through all the bearings and replace them. Partly for peace of mind, and partly because I don't know how rough of a life it's had. Does anyone sell a complete kit with all the bearings and flanges I would need to complete the job??
Does anyone sell a complete bearing and flange kit for the Max IV???
Did you figure out the clunking noise? My Max IV left rear axles mounting bolt would come loose if I drove it do aggressively. I looked at my rear axle compared to the rest of my axles and it was protruding about an inch more then the others. I jacked it up pounded the tire and axle back in, put lock tight on the bolt, and tq'd her down. The clunking noise was from the chain rolling on the sprocket at an odd angle.sigpic
Grandma's Real-Rose Camo! The next best thing from Realtree!
You can always go this route if you want to have heavy duty bearings that will last much longer than stock. Other than the increased initial cost of the parts (over the factory ones) these should outlast the factory ones by a good margin. I cannot say how much longer life you should expect considering I have not completed the switch as of this post, but it should be significant. The bearing housings in the kit are much more robust than the factory "stamped" housing. They should give much more protection than original.
