so I am upgrading my #40 sprockets to #50,my #40 sprockets are 26 tooth and the circumference measurement is the same as a 20 tooth #50 sprocket.All the posts I read say a max uses a 22 tooth #50 axle sprocket,my machine is a max in a scrambler body and I dont think I could use 22 tooth sprockets because the chain might rub the scrambler body underneath the sprockets,is there any issues with me using 20 tooth #50 sprockets instead of 22 tooth,and why the diameter difference in a 26 tooth #40 sprocket to a #50 22 tooth sprocket?Richard relics told me my machine is probably a 1969 or 1970 due to the sprocket sizes so I dont knowledge if sprocket diameters changed in a certain year.
max sprocket conversion question
hi
The only ratio u need to worry about is the t20 to the axle or idler shaft .
The axle sprockets that run chain between need to be all the same size, eg front to mid/ mid to rear.
Use the largest diameter sprockets u can fit in
The only reason u get concerned with axle sprocket size is to allow for HP and RPM of the chain . There are charts that exist for this . 99% 6x6 need a lot larger chain.
The Muddox uses double no60 chain
tomo
