Do all max IV's use the same amount of chain? For instance, do the early max's with round head lights use the same length chains as new max's? Here is why I ask:
I replaced the center axle bearings and sprockets. While I was in there I thought it would be a good time to replace the chains. I removed the middle to rear chain and found it to be 116 pins... I have read on here that it should be only 114. I had some cheap chain laying around, so I broke it to 114 pins and made an attempt to put it on. (I wanted to be sure what length I really needed before I bought and broke good chain.). I don't see how I would ever be able to get it connected at 114 pins?? The rear axles are splined a snap ring and the center are solid pinned if that makes any difference.
Any ideas?
Any ideas?
