Hi Guys,
Started replacing the chains on my Max yesterday. They were beyond sloppy. While my Max was off the ground I started moving the tires and noticed about 1/16-1/8 in. play in every axle. Lt rear more than the rest. 3 of the chain tensioners were toast or missing. Looks like I need to replace some bearings. The inners seem o.k. I'll check to see. Don't think I will have to run it through any water so leaking isn't the issue. Unit has about 200 hrs on it. Prior owner just let the chains go and I reap the rewards. The only problem he said he had with it was it pulled to the right. Duhh! I could actually make the chains meet in the middle on all the axles. Right jackshaft vertical chain had about 2 inches play. Left side not much better. Pretty much rode hard and put up wet. Sucks to be me today.
Looks like I'll be reviewing Mikes bearing change video a couple times. Not to mention about $400. worth of parts.
