Does anyone know where is a good place to get springs and all the parts to make a t -20 shift kit
t-20 easy shift
I did it on a maxIV a couple years ago with springs I had laying around.......I wish I hadn't. The springs do make shifting easier than a stock set up, but it is still possible to have only one side engaged when you take off. Splitting the shifter is a far better way to go. One of these days I will have to tear mine back down and throw in that second lever and rod
This is a how-to video for making a split shifter for your T20 Skid Steer transmission. Instead of having one lever that controls shifting of both sides this mod will let you shift each side of the transmission independently.
Or for a single seat setup:
Wiggy:
When you split the shifter, you are only trying to put one side in gear at a time. This makes it MUCH easier.
