Has anyone seen this type of wheel with a built in winch on the rim? I found a max in florida that has one on it for sale on craigslist, here is the add so u can understand what im talking about: Max IV
Max with wheel winch
This place used to make them but it was a few yrs ago so I don't know.
Walker Wheel Winch
PO Box 3295
McDonough, GA 30253
Not too hard to have somebody make Ya a setup like this, just use rims as the drum. can unbolt them pretty fast. bigger rim here but the consept is the same on a 8" up etc
Thanks Nubs. I like that idea as a back up to my winch on the front. Especially if there is no place to winch from in the front i can use a back wheel to pull with. Of course this depends on the price it takes for me to fab one up in the shop compared to the cost of buying a winch for the rear.
Speedy Metals 1-1/8" 12L14 Steel Hexagon
Cut the hex bar to whatever length and tap both end's, replace 3 of the 5 lug nuts with them and use a rim with the same bolt pattern. use trailer lug bolts to mount the rim drum, no studs stickin' out if ya remove the drum
could drill, tap and chamfer the adapter mounts on a lathe pretty easy.
you know...on this idea just tossing this out...with two you could in theory doe some serious sidehill by having one spooled with cable and the other unspooled...wound opposite so the spooled one lets line out and unspooled one takes line in....makes for a nice safety is all I am saying...
Or jack one side up and you could with a machine drum hace a capstan wich setup etc...
many options ideas etcMUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
I agree that a setup for the option for 2 would be the way to go. adapters each side. could then choose which ya wanted to use. As long as the adpaters were flush to the tire they would not cause to much problem with catchin' on stuff. Maybe leave the mounting bolts in the adapters to keep the mud out
