6 wheeler.jpgHello everyone from 9,000 ft in the snowy Rockies. I just inherited a 6 wheeler and this seems the place to be. Have no idea of manufacturer, it has a 2 cylinder JLO Rockwell motor, a Walbro carb and a Skid Steer transmission. Any info would be helpful as it doesn't run, and hasn't in at least 20 years. I am going to attempt to rebuild it and get it running, once all this snow melts.
New to forum and 6 wheelers
Drew is right, it's a Max II. Is it a 340cc or 400cc JLO Rockwell engine? If it's a 400, then it's the Big Max model, if it's a 340, then it's a 340-T model. The Max II is a great machine. What is the serial number on the machine? It'll be able to tell us what model year the machine is. Also, it almost looks like that might be the original Max trailer you have along with it, which was available as a Max accessory from Recreatives in the 1970's."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Well, on a global scale we're practically next door neighbors. That is definately an old Max ll. If you have any questions about it, PM me. I don't know everything, but I just went thru mine and it's performing nicely. There is also ton's of information on here. The "How To" section is particularly helpful. See ya!Our motto in the Strategic Air Command was "Peace is our Profession". If you don't believe it we'll bomb the hell out of you.
Are yours the #40 chain or #50 chain sprockets? Amphibiousdrew or I have a couple extra sprocket sets laying around for you.Originally posted by lowrider View PostAlso found the sprockets where they bolt to the axle are all loose and egg shaped. It appears some are cracked."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
