Hi, first post here. I would appreciate some guidance before I tear into this thing too much. I have a late 90s max IV that has had a gradually worsening issue where the left stick requires more and more effort to operate and finally it has gotten to the point where I just can't steer the vehicle (not to the left at least). The gear shift seems to work OK and the right stick operates pretty well. Is a T20 rebuild in order? What is the specific issue that causes this? Thanks in advance for your help, I've found this forum to be really informative.
Max IV left stick stuck
I've worked on a machine with a rusted pivot tube. Disconnect the linkage from the sticks and see if you can easily move them back and forth. If you cant, the whole assembly can be removed. Unfortunately, I had to cut the pivot tube shaft in half and drill the remaining material out of the sticks and fab a new pivot tube.
page 5 item 48,49 and 3. Disconnect 47 and see if it moves easy.Last edited by liflod; 03-29-2015, 07:57 PM.
If the oil down the handle didn't work,bite the bullet and pull the entire assembly out,bolt the flange down to a sturdy bench,pour the penetrateing oil to it as u work it back and forth til u get them both of the shaft,clean,polish,butter up w/anti seize and reassemble.yea it sucks but it'll fix it. Bill d
To follow up, I was able to hold the shaft in the tail stock of a lathe and turn a drill in the lathe chuck and drill the old rusted shaft out of the control stick. I got a new piece of 5/8" mild steel ground shaft from McMaster and got somebody to weld it into the base plate. Greased it up with marine grease and reinstalled it and the difference is unbelievable. This thing has never been so controllable under my ownership. Thanks for the tips everyone.
