found the leak in My Max IV
  • found the leak in My Max IV
    I found at least one leak, I found a 4 inch cut in the bottom inner side. I used a harbor freight plstic weld kit to try to fix it. I guess will see how it goes.
    Max IV
    Dodge Ram 2500 4x4
    swamp buggy powered by 1947 willys flathead
    Can you share your experience with plastic welding? I would like to buy a wrld kit and want to learn more. Was it easy to weld the crack with this kit? Thanks.
      I used the kit to fix a boat seat. its not hard but I don't think I melted enough in to fix it. the other problem is that 6x6 does lots of flexing. but will let you know.
      Max IV
      Dodge Ram 2500 4x4
        Thanks.
          So far its slowed down the leak.
          Max IV
          Dodge Ram 2500 4x4
            Well my plastic weld broke.
            Max IV
            Dodge Ram 2500 4x4
              Try, try again. (Did it break outright or over many rides?)
                And did the weld break or did the HDPE break next to the weld?
                I would re-weld it and then epoxy over it. Member thebuggyman1 used this epoxy: Epoxy by the Leading Epoxy Manufacturer | WEST SYSTEM Epoxy with good results in his Max II Bigfoot build: http://www.6x6world.com/forums/max-a...-tall-tub.html
                  Mike I have boats and use that west system 610 epoxy alot.
                  Max IV
                  Dodge Ram 2500 4x4
                    I rode it a few times before it broke. some of the weld held. I welded it again. maybe I didn't have it hot enough.
                    Max IV
                    Dodge Ram 2500 4x4
                      I used an aluminum wire screen and scraps of poly to do my repairs. I took the screen and melted it into the poly all around the crack using a soldering iron. Then I took very thin layers of poly salvaged from potting containers and melted/pressed them into the wire mesh using a heat gun and an auto body dolly. I probably used about 4-5 layers of poly to complete the repair. The weld held up after pounding it with a rubber mallet and pretty hard riding. To make it pretty, I sanded the rough spots and lightly melted the roughness with a heat gun to give it smooth appearance. Prior attempts to fix without the wire mesh failed miserably.
                      Here a some pics of the damage and work in progress attached....
                        Thanks for posting the pictures. I just bought and put on some g flex west system epoxy. I will let you know how it works.
                        Max IV
                        Dodge Ram 2500 4x4
                          So far that epoxy has been holding up I am going to run it over thanks giving. will keep posted
                          Max IV
                          Dodge Ram 2500 4x4
                            I rode a bunch this week and beat on my machine and the epoxy is still holding.
                            Max IV
                            Dodge Ram 2500 4x4
