2003 Max IV resurection
I removed the outer seal on the middle bearing so it is exposed to the grease inside the bearing cage. When I pump grease into the bearing cage it will lube the middle bearing. The outer bearing still has a grease zerk in the flange on the cage.
I wanted full support right to the hub and a water tight solution. This will be it for now until I get on with the UHMW bearing blocks.
