Started reassembling my Max IV and need some help on the cupped washer that goes with the bolt that screws into the end of the axel that is on the inner frame rail. Does the cupped washer face with cup in or out? When I pulled them out some were faced in and others faced out.
Max IV axel washer
I always put the convex side toward the bolt head and it will flatten as you tighten. If nothing else it may ack as a lock washer. Put a dab of blue (removeable) lock tight on the threads too.What it lacks in ground clearance it makes up for with traction.
I assume you are talking about a belleville washer https://en.wikipedia.org/wiki/Belleville_washer
Listen to tbone, he has it right.
