Hi I'm Having problems getting a belt for my Max II . Its a Recreative Industries belt Made by Carlisle #15252AA Made in usa 0405-265. Mud Ox site does not have that # and I have had any luck with Carlisle. Any info that would help me locate one would be appreciated. In the meantime I'm searching.
Cross reference drive belt
Mr. TDOG50, I am sure that the max experts will be chiming in very soon. in the meantime it might be wise to tell us what engine is in your Max11 and what year it is. How far north is northern Ontario to you? North of Thunder Bay?Originally posted by tdog50 View PostHi I'm Having problems getting a belt for my Max II . Its a Recreative Industries belt Made by Carlisle #15252AA Made in usa 0405-265. Mud Ox site does not have that # and I have had any luck with Carlisle. Any info that would help me locate one would be appreciated. In the meantime I'm searching.
BELT
CATEGORY PART NUMBER NUMBER ON BELT DESCRIPTION CLUTCH TYPE LENGTH X WIDTH
ALL MODELS 15252 15252AA BELT BRIGGS & STRATTON & TECUMSEH COMET 44 7/8″ X 1 3/16″
SUBSTITUTE BELT
DAYCO MAX 1039,
DAYCO HP3003
Please note, I have spoken with a MAX technician and he states that while the specs call for 1 3/16" width, most belts shipped are undersized, closer 1 2/16"
By now you have this, but Mudd-Ox DOES stock that belt. 15252 BELT, DRIVE BRIGGS & STRATTON & TECUMSEH - MAX II
I just went through my old posts and found the belt number, its a 1092M3 Dayco Ultramax belt.Originally posted by Canadian_Zuk View PostLet me check when I get home tonight, I think I have one I bought by mistake for my max IV. If I do have it you can have it for the cost of shipping. I'm also in Ontario.
I've had great luck with buying the 1-1/4" wide belts. It lets them ride higher on the secondary giving more low end. I always ditch the stock rubber motor mounts and add unistrut to get better adjustment and performance too. This gives more choices for length as an added benefit.Originally posted by hipowerone View PostPlease note, I have spoken with a MAX technician and he states that while the specs call for 1 3/16" width, most belts shipped are undersized, closer 1 2/16"
I'm running a 40 horse big block Kohler in mine so it just won't be the same......
Using 2 with the stock motor mount plate would be the simplest set up, but I think there's a reason it doesn't slide right in. My memory is failing here, but thinking of how the frame is and how things fit in there you may be better off putting 2 struts side-side perhaps even with a spacer between them and the frame. Then bolt the engine to 2 struts running forward-back. I also like using square washers.
