Just replaced both rear axles and sprockets one from recreatives and the other from 6x6parts. They are both new, how come there is so much difference in adjustment when turning axles. Are the sprockets off center assuming axles are straight. Max iv
Chain play
There were different spacings by serial number and also axle lengths, if its under 1\4 you could space axle at inner bearing with set screw sprockets or shim sprocket. I'd check the axle lengths against originals. If the outside lines up you could re groove the axle or turn sprocket on axle and relocate set screw hole for chain alignment.sigpic
where are you located, i have a max iv that i would sell you if your close. its not complete but has all kind of good parts. no top or tank. but otherwise complete
has the ultimate bearings and all new sprockets axles and chain and 20 hp opposed twin engine
