Picked up the engine for the diesel swap last nightime. It's a kubota d722. I will be putting it in my max iv. I am going to put the transmission under the seat in order to make room for the diesel and keep the cog as low as I can. This is my winter project so updates will be slow. Here is a pic of the engine.
Max iv diesel swap
A little more progress getting things ruffed in. I am going to run a polaris secondary which is 10 3/4 o.d. so i am going to have to pick the tranny up about an inch. I am also moving the tranny farther forward than i had planned. This is to shorten the drive chains a good bit. Downside to that is that it will take a pretty long belt. The engine cannot go forward anymore because off the backseat which i also moved 3" to the rear for more leg room. Battery will be off set to the right side of the machine. After going to my steel source i have decide this beast is going to be equipped with some massive 1 7/16 axles. Planning on finishing the motor mounts on monday i have some machining to do on them.
those are the tires I really wanted to run.
