Why can't you get them in canada? I couldn't find anyone that had them in stock so i called interco themselves and they sold them to me directly. Said they have lots in stock
Max iv diesel swap
Originally posted by miller_time View PostWhy can't you get them in canada? I couldn't find anyone that had them in stock so i called interco themselves and they sold them to me directly. Said they have lots in stock
Originally posted by miller_time View PostSounds like you need to bring your 6x6 to Ashtabula. Order the tires and have them shipped to a 6x6 member and get them at Ashtabula. Just a thoughtI ended up getting a set of 26x14 Vandetta tires and so far I've been pretty happy with them. I'm sure the Vampire would be better in the mud, but would it skid as easily? I do play in the swamps and lakes of the Ottawa Valley a lot and appreciate how fast the Vandetta tires are on water....we'll see what happens next, I kinda want a Max II now lol
Yes the vendetta look to be a good tire but the price tag sent me onto the vampires for about 1/3 of the cost. Not so sure how well they will skid we will see. The weight is also a bit concerning.planning on turning this motor up a little. hopefully it will be enough to run these tires. May be a good excuse for a turbo!
Originally posted by miller_time View PostYes the vendetta look to be a good tire but the price tag sent me onto the vampires for about 1/3 of the cost. Not so sure how well they will skid we will see. The weight is also a bit concerning.planning on turning this motor up a little. hopefully it will be enough to run these tires. May be a good excuse for a turbo!
I bet you find though perhaps a tad slower far more versatile and usable machine.
Are you doing the T20 shifter mod to counter rotate too ...its worth its weight in gold being able tooMUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
Yes i am doing the shifter mod while i am at it. These little diesels actually turn 3600 rpm so it would have the same speed as the briggs it replaced. But i changed the gearing for more torque so i will loose some top speed. I may turn it up to 4000 or 4200 rpm and see what happens. Most likely have to advance the timing a bit and definitely add more fuel.
max iv diesel swap
You are doing a really nice job Mr Miller. Diesel power,t-20 up ahead on the floor, and I am so glad to see your excellent version of overhead bracing to add to the stock style of on the bottom T-20 mounting. Will look forward to the first balls out field test. good luck and best wishes.
Originally posted by philipatmaxfour View PostYou are doing a really nice job Mr Miller. Diesel power,t-20 up ahead on the floor, and I am so glad to see your excellent version of overhead bracing to add to the stock style of on the bottom T-20 mounting. Will look forward to the first balls out field test. good luck and best wishes.
Thought about spacers but i have the old hollow axles and a bunch of 1 7/16 ground bar stock laying around. so i figure i may as well upgrade the axles while its apart and add the 2" to the axle. I got a real good deal on all the hardened sprockets so i am just going to key the axles.i think thats how mudd ox does it so it should be ok. Thanks for the input though
