I have a Max IV I have recently replaced the entire drive train axles, sprockets bearings etc. My old axles had 7/16" diameter bolts holding the sprockets to the axles the new axles which I got from RR had 3/8" diameter holes and came with grade 5 bolts. The bolts on the front axles sheared off I replaced them with new grade 5, then the bolts on the center axles sheared off, I replaced with grade 5. The rear have not sheared as of now I would think they would have went first. My first thought was that I over tightened them and stressed them, so when I replaced them I backed off a little I also have them double nutted. The reason I did that was because the old blots use to come loose.
THOUGHTS?
One other thing on the way to my treestand there is an exposed tree root I cross could this have caused it? I do not run tracks.
THANKS, Dave
THOUGHTS?
THANKS, Dave
