Maurader... my point is nothing. I misread "MuddTrax". I had thought it said Mudd Ox.
Anyone else having trouble (and sick of it) with constant maintenance?
ARGOJIM, I am still interested in the Tinger but have not had a chance to test drive one due to them not having a dealer in the US and my international travel being curtailed due to budget cuts where I work. I also think the MuddTrax is an interesting machine and I might get a chance to test drive one this summer, I'll let the forum know what I think of it should that come together. I really want a tracked machine so I have been holding off until I can test them out, hopefully soon I will find one that I like well enough to purchase.
Rusty-Gunn, no worries, I thought that was what happened but wasn't sure. I know the MuddOx is a good machine, I just like the fact that the MuddTrax has just tracks, real suspension, great ground clearance, is hydraulically driven just like the Ox, and has a single joystick to control everything. I hope to test drive one soon.
I've driven some single joystick machines before. I prefer the two stick application as the one gets jittery as the machine bounces along with one hand control. Not that this is a criticism, just an observation.
Mudd Trax seems interesting, however that style of tracks isn't really known for swimming ability.
Noel, it seems that no tracked vehicle, whether they have the tracks over low pressure tires or the system is track only, is great at swimming, especially when compared to low pressure tires only, but the MuddTrax actually does OK since it has such a high ground clearance that the top of the track is out of the water so it isn't fighting the bottom half of the track for propulsion. A Max IV with 26 inchers or even an Argo with standard tires would probably smoke the MuddTrax in a race in water but I think overall I'd rather give up a little speed in water for all the advantages of the track system, but then that's just me, it's why they make vanilla and chocolate.
Yep, they start out at about $35K list, but a comparable MuddOx will cost you at least that much and you won't get a pure track system or a single controller like on the MuddTrax. MuddTrax also has real suspension and higher ground clearance than the Ox, they just aren't as established yet as the Ox brand, but I think when potential buyers compare the Trax with the Ox they will see that the MuddTrax is a better value. Just my observation though, I haven't test driven the MuddTrax and I know the MuddOx is a very good vehicle having driven it at Matt's place a while back.
My concern with all aatvs is the abundance of chains. In an industrial maintenance mechanic, I know how long the best of chains and worst of last. And when you have 8 of them to upkeep plus a snowmobile clutch, that’s a lot of maintaining. A lot. They can’t even remotely compete against quads and sides sides. Plus the tub gets wet, which helps ruin everything.
Don’t get me wrong, I love these machines. But I’ve been pondering a better way since I bought one. For the small number of riders there’s a lot of trouble with them. I think muffin may have kicked some serious ass with the vengeance, because everything’s over engineered for the lower power. But reguardless, can you run this 50-100 hours without touching anything? That’s what makes this market a difficult one to thrive in.sigpic
I dont really have maintenance issues. Even after a long weekend of beating on them I go home and spend maybe an hour cleaning and greasing. I dont run the top of the line bearings or chains. I keep the bearings greased after each ride. I run o-ring chain and lube that after each ride.sigpic
Rabbit929, I share your concern about all the chains and the stretch you get from them, the idlers and chain tensioners that you have to keep up with, the lubing of the chains, and finally, the eventual snapping of the chain if you don't replace it in time. The beauty of the MuddTrax is that there are no chains, just two hydraulic motors turning two sprockets for the true track system. All the maneuverability of the MuddOx due to the hydraulic drive but none of the chain hassles the Ox has. And you mention getting things wet, the MuddTrax description says that it has no holes going through the body of the machine so that will go along way to keeping everything dry below water level since the track system is external to the body, unlike the Ox that has the wheel bearings fighting water intrusion every time you swim it. On paper, the MuddTrax seems to be a superior machine and better value than the MuddOx, would love to see a shoot-out test in one of the off-road magazines between the two of them.
The problem with MuddTrax and the Cushman Tracksters and similar machines is that when they throw a track it will sideline the machine until the track is put back on. With just a single hydraulic motor per side and a driven sprocket, once the track is off its a bear to get back on. With your typical 6 or 8 wheel drive Max, Argo, or Ox, you still have multi-wheel drive with tracks or not. Several years back I threw track on my Argo, I winched it out of the mud hole, spun the machine around, and winched the track out and reinstalled it in the dry. If that was a machine with a single hydraulic motor per side, it would have been difficult, at best.
I like the idea of hydraulic machines, as well as tracks. I really like the fact that those have a suspension system as well. I guess it's a matter of every machine having advantages and disadvantages that can materialize any place you may be.
Just my 2 cents but I have very little if an MX issue's, my chain's haven't stretched, O ring chain, bearings are a non issue, engine, clutch, tranny are all fine and I ride my machine hard when I do. the only issue's I have is I always try to modify something.. but those items are not needed
This is why I’m becoming more interested in a muddox veng because my 94 vreaks down on me every time I use it. I feel it will be much better with a new tranny and clutches, but with all the undersized non-print chains, once those chains stretch, I’m back to square one againsigpic
