Kohler magnum 20
  • #16
    Originally posted by 6X6 View Post
    Your not too far from Allentown, right? I don't know the local roads on your end, but your probably about 3 hours most from me (2 1/2 to Allentown, give or take) I do hope to have at least a little Get-To-Gether / Trail ride sometime in the spring/early summer, but every attending machine MUST float, Theres miles of trails and rough roads on the hill, but you will spend quite a while in the water first to get to them
    Sounds great. I have to get a trailer before I can go far but have some trails here till then.
    1998 Max IV 20hp Kohler Command 26" Tires
    • #17
      It's finally here.
      This is it. 1998 Max IV, 26in tires, 20hp Kohler Seems to need a little TLC. Throttle cable is stiff to hold. Choke cable needs to be reattached. Came up in rain and snow so it was soaked. I took it out for a short tryout and it seems a little down on power but that could be due to the cable. Previous owner said it was a new heated cable and needed to be adjusted.
