Originally posted by demonflea
View Post
Shakedown run on new to me maxiv
26 ride ruff but more air you put in the worse they ride .. but wait till you go swiming . it will fly with 26 . those 26 are made for a 4000lbs of trencher not a 800 lbs of atv also if you do not have those new style k rimes you might have to run 3 to 5 lbs of air . .. make shure your plugs are in . robbieLast edited by rdr; 10-29-2008, 09:31 PM.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
R.I.P sage rogers 4 11 09 .
How do I tell if I have K style rims?Originally posted by rdr View Post26 ride ruff but more air you put in the worse they ride .. but wait till you go swiming . it will fly with 26 . those 26 are made for a 4000lbs of trencher not a 800 lbs of atv also if you do not have those new style k rimes you might have to run 3 to 5 lbs of air . .. make shure your plugs are in . robbie1998 Max IV 20hp Kohler Command 26" Tires
there should b a k in the size on the rims and if you look on the site under gallery . tires mike has a pic of the bead lock .Originally posted by demonflea View PostHow do I tell if I have K style rims?1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
Thanks Robbie, I really appreciate having all you people and your knowledge. And the fact everyone is willing to help those of us just getting into the sport. ThanksOriginally posted by rdr View Postthere should b a k in the size on the rims and if you look on the site under gallery . tires mike has a pic of the bead lock .1998 Max IV 20hp Kohler Command 26" Tires
OMG what a difference the tire pressure made. It's like a different machine. I'm running 3lbs of air and it rides like a dream compared to before. Thanks Robbie any other tips for a newbie?Originally posted by rdr View Post26 ride ruff but more air you put in the worse they ride .. but wait till you go swiming . it will fly with 26 . those 26 are made for a 4000lbs of trencher not a 800 lbs of atv also if you do not have those new style k rimes you might have to run 3 to 5 lbs of air . .. make shure your plugs are in . robbie
keep your chains lubed and berings greesed and don't forget your plugs. they are lifesaviors . also keep your max cleaned out sticks and trash can kill your chains and cause them to break .carry a extra 530 master link at all times . robbieOriginally posted by demonflea View PostOMG what a difference the tire pressure made. It's like a different machine. I'm running 3lbs of air and it rides like a dream compared to before. Thanks Robbie any other tips for a newbie?
Last edited by rdr; 10-30-2008, 08:29 PM.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
coollllllllllllllllllllllll glad you are enjoying your max IV robbieOriginally posted by smokin cigarettes View PostRan it on the river tonight and had a great time. It swims good if you lean it like a V-bottom boat. I still have a broken throttle, hopefully when the new on gets here it will help out with the performance.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
