Plungers are leaking slightly will it turn and stop with levers pulled back if bands are bad
t-20 transmission
Yes, I believe it will turn and stop with bad bands, but it should make strange noises and have reduced power because of the metal-on-metal contact between the band and drum. It will also ruin the bands and drums to run it like that.Plungers are leaking slightly will it turn and stop with levers pulled back if bands are bad
Let's go back to the basics. Your original post said the clutch spins but you have no power. Tell us the recent history of the machine. Was it running fine but one day lost power, or has this problem creeped up on you? Have there been any recent repairs, adjustments or maintenance? In a previous post I suggested you make sure the bands are correctly adjusted. Have you done that yet?
