Drain plugs
  • Drain plugs
    I am new to the max II and just restored one. I was wondering what drain plugs I should use?
    ben...you can get the quick snap rubber exspansion plugs for a 3/4'' hole from mcmaster carr co. check their website here online. there the ones i use and others also . they have worked fine for me and last . johnboy va.
      Thank you I will look into it
        I ordered a bag of body plugs online but the rubber ones Johnboy recommended would be much better. I was just planning on a dab of silicone to seal/glue them in but figured they should still push out if I need to drain or clean my lower out.
        DanW
          ben ...check your hole size before getting the plugs . i can't remember if the original max 2 holes are 3/4'' or if i drilled mine out a little bigger so a 3/4 '' would fit . j.b.
            Drain plugs 2003 Max II
            Where can i get replacement drain plugs and does it only gave 2 drains. I just bought it and havent had a chance to really fully look it over. Thanks
              pinnacle... it does just have the 2 holes in the rear . the original plus are a snap in plastic plug. probably '' richards relics '' sells them . the rubber expansion ones like i mentioned above are better . j.b.
                Thank you
                  I have been using rubber expansion plugs (live well drain plugs) for nearly 20 years and the only reason I have had to replace them is that I lost a set by misplacing them. I usually carry an extra set with me on trips for that reason. They work great. I have the kind that is like a lever that folds over instead of a t-bar. They have never failed me and never popped out while wheeling. I would stay away from the snap plugs, because you WILL have to wash out the tub from time to time and the bearings will leak a little especially if you are out floating in a pond for hours while fishing. If I remember correctly, mine are 3/4" diameter as well, but the best thing to do is measure the holes before you buy.
                  Borrowing tools is for the weak.
                  2000 Max IV, 25hp Kohler Command, 26" Titan Tru Power AT's
                  1996 Max IV, 18hp Briggs, 24" Serwas
                  1998 Max IV (project in waiting)
                  1995/1999 Max II, 16hp Briggs, 21" Rawhides
                  Hustler 950 (Project in waiting)
                    RI used 3/4" diameter Cap Plug (trademark name) plastic plugs when they manufactured the Max.
                    Max 6 Wheel Drive
