Guy goes into a garage to grease bearings.....
  • thats o.k. mike ...take your time , it's a really cool project . the portal extensions look good mounted up. nice tub clearance . you got more parts on there than mcmaster -carr stocks !! you still have another machine to bring to busco ? johnboy va.
    • Really good craftsmanship, I don't know where you find the time, I am always busy.
      • Originally posted by mightymaxIV View Post
        Yeah, I might be neglecting some other things this week.
        Was going for the marathon finish, but never thought these boxes would take so long to assemble.
        Moving on....
        • Sorry to hear it will not be ready for Busco as we all know how hard you were working on it for that goal. Just keep on putting it together with the care you have up to this point and we will see it on the trails. Please post some video of it when it is moving under its own power.
          • onlyonce ( again ) ? sorry you won't be there . it may be the smallest group ever , but never the less a muddy mess . what ever happened to scott and john ? j.b.
            • Did some dismounting of old tires and mounting of new ones.
              Couldn't get beads to seat for the life of me. Used 2 ratchet straps.
              Bought an air blaster to seat beads.
              Too nice outside today on this first day of spring. Went outside and breathed fresh air.
              No other work today.
              Tomorrow, after more Advil.
              • Haven't posted in a few, so I'll catch up.
                I could NOT get those darn beads to seat, and I've done quite a few tires by hand.
                Took them to firestone to see if they would seat them....They said no.
                Went to Mavis tire and they jumped right on em.
                Three guys on one tire. Took them over an hour to do five tires (I did one, and it took me three hours) and I'm wondering how much it's gonna cost.
                They did the same tricks I did, ratchet straps, Cheetah air blaster, even tried to mount them to there machine. Lots of cussin and a few owies later they charged me $10.00 per tire which I thought was cheep considering the effort.
                THANKS MAVIS!
                • Decided I wanted a larger oil capacity for my turbo motor so I made a bigger oil pan and dropped sump.
                  Used an old Kubota oil pan so everything was similar size.
                  Tried out my new Woodward TIG machine (dang I need more practice) and TIGed together the oil pan. Used silicon bronze to piece together the oil pickup and added some support.
                  It does NOT leak. I tested it.
                  It's now 4 quarts instead of 2 1/2 quarts.
                  • oooooo, some shinny bits attached.
                    Had to relocate the dip stick to the other side of the block and use the original location for the turbo oil return.
                    • Got the primary chains set up from the T-20 to the rear sprockets.
                      I have a lot of adjustment for these and I can do it from the center of the rig instead of under the engine.
                      • Engine is in for the last time.
                        Nice and low. The stock hood with no bump up fits nice. I will not add a rise to it.
                        Tomorrow I mount the radiator and intercooler.
                        And yes, I will need to add some space between the 1195 and the tub.
                        • mike...it's a work of art , the picasso of max 4's . you must be excited about the first run . you got time to work any bugs out before we can gather at busco later , since we missed this one . johnboy va.
                          • Originally posted by john swenson View Post
                            JB,
                            Today I planted some grass in my yard.
                            I'm thinking I may be planting more when I test drive this.
                            • I have seen those Mud Bug tires on Lee's Argo Frontier and Noel Woods MaxII. On the Argo they swam a little, on Noel's MaxII they swam about 2 mph. I have only seen one mud tire out preform them on an AATV and that is a vampire ASX. THERE is extensive video of Noel's MaxII at River run so you can see for yourself just how well that machine works. Lee's Argo smoked my MaxIV several times in pure mud
                              • Really coming together now. Won't be long before it's tearing up something. What secondary are you running?
