Hi, I have a fully restored max ii.. Anyway is it normal when revving it high in neutral for there to be a big vibration? Also what do you do when you start adding some lights and a bilge pump? Do you install a fuse box so you don’t have a lot of wires going to the battery? Thanks
Vibration
Ben, you should not have a big vibration. So, first look for visible signs of a problem such as a wobble in the driven clutch or anything else that appears to be running "out of true". Next I would remove the belt and the drive clutch and rev the engine. Don't run the drive clutch without a belt.
If there is no vibration in the engine I would then check to see that clutches are fitting tight on their respective shafts.
Originally posted by Ben Selby View PostWhat’s the best way to remove the clutch on the engine? Thanks
