Hi, I've got a 70's max II (no vin #, not exactly sure the year) that I'm converting to electric drive. The body is in great shape, but came with a few haphazardly placed bolts with wing nuts and two flimsy broken hinges attaching the upper to lower body. It's a hassle to raise and lower or detach the upper body. Questions: How was this set up from the factory? Were the hinges on the front stock and if so how were they attached? There's not really room for nuts and bolts. Were they loose pins so the top could be detached without removing the hinges? What kind of fasteners were used as hold downs. Has anyone come up with a better way to set this up? Thanks for any help, if the temperature here in VT would rise a little bit from the current -28 degrees I'd be ready to test my rig.
David
David
