It's in good shape, runs well EXCEPT while the seller had it on the market his son continued to use it. The T20 clutch bolt came loose when he was riding it and the keyway is also missing. It must have spun on it's shaft a bit because after I tighten the bolt back up there is a little bit of play...
So I guess I should replace the clutch ? I assume the engine and trans has to come out, but it doesn't look very hard to do. Where's the best place to buy the clutch ?
Is there supposed to be some kind of thread locker Loktite, etc) on the bolt threads ?
Any tips from anyone who had encountered this ? I haven't yet tried just replacing the key way and tightening the bolt...I'm hoping just the bolt came loose allowing the keyway to pop out. The guy reduced the price several hundred because of this.
Also need a new ignition switch...is this a universal type or is it an OE part only ?
