I just did the split shift mod last weekend and thanks to larry for the great video. I think I finshed it in and hour took longer to dig up a 1/2 inch pipe coupler than to weld and cut everything. To those who do this simple mod, watch out I spun mine so hard the fuel pump could'nt pick up fuel and killed the motor. Also thought my son was going to hurl.
MaxII split shift modification "How to" video
lol, Glad to help and thanks for funny storyOriginally posted by nairb35 View PostI just did the split shift mod last weekend and thanks to larry for the great video. I think I finshed it in and hour took longer to dig up a 1/2 inch pipe coupler than to weld and cut everything. To those who do this simple mod, watch out I spun mine so hard the fuel pump could'nt pick up fuel and killed the motor. Also thought my son was going to hurl.
it is good it remains controlable. I had thought this mod made it sensitive.Originally posted by LarryW View PostYes it is completely controlable with the sticks and throttle. You could put a small pin in in it to lock it back if you choose.
Can you elaborate on the pin? Lock what back? I beg forgiveness but I'm lost. Thanks.Stand for the Flag. Kneel for the Cross.
After building the "split shift", drill a hole into the middle of the "split" to drop the pin into. By doing this you efectively bring it back to oem standards, but on your terms. It keeps the split part "tied" together just like it was in factory condition. Which means any time you wish to use the split shift, just pull the pin. Put the pin back in and it does not split shift. Hope that helps explain your question...Can you elaborate on the pin? Lock what back? I beg forgiveness but I'm lost. Thanks.
You could put a pin through the tube and the center rod to lock it back to normal shifting but you would have two shift levers doing the same thing. But really it's not needed. If you don't want to split shift you could just move both shifters to the forward or reverse position. Hope it helps you.
