MPS - My Personal Springer
  • #61
    well went to PHOENIX this weekend and picked up all my parts for GOLIATH
    theirs so many parts that im going try to post pics in the order of assymbly..
    the first pics are of finishing all the riveting..if you own a max iv then you will notice
    that the rivets on the side of the max are in backwards so the side plate will fit
    properly and the back skid has 7 extras so body wont have a big gape for crap to get into..like with any custom build you always try to improve...HEY ITS YOUR MONEY..
    • #62
      I would have used Rhinestones for the Country look. But that's just me.
      Bridget
      • #63
        those will match the BLING BLING wheels i have
        • #64
          heres the inner bearing flanges being drilled with a templete for small bolt pattern,
          these are the large 72 mm bearing flanges with the small bolt pattern..you have to make a good templete to do this..then on the area for the grease fitting i take the fitting out and use a 1/2 bit at an angle to bore it out so grease hole in bearing will line up..i do this so i can use a small needle type grease gun for greasing, you will definatly
          see grease being pumped in..
          • #65
            Very nice WFO. Look Forward to seeing this machine on the finished end.
            • #66
              That looks cool! I bet your getting excited now! Nice work.
              • #67
                These projects are as much fun to start as they are to finish.
                • #68
                  WOW the springer plates went right on..almost peed myself, i was expecting some kind of issue, some clearence issues with factory skids but
                  that was easy to overcome..taken shape now.....I AM SO STOKED..i have to control myself...im starting to drule
                  • #69
                    That drooling thing. That is normal Whipper makes good parts Had the same problem with the Crush: NO ISSUES
                    • #70
                      • #71
                        you know how those coronas are
                        • #72
                          so this afternoon i finished up the inner bearing flages, installed them along with
                          the axles and gears..notice the grease hole..it sure is nice working with all new parts
                          • #73
                            It is always fun to follow these projects. I am still wondering about that little V8, that thing looks like it rocks.
                            • #74
                              MORE PARTS from R.I....very nice clutch..far cry from that old outdated COMET..
                              GOLIATH will be happy...going to pull the T-20 out of the old max IV and install
                              it in GOLIATH..T-20 was just gone through last febuary, new bands bearings seals ect.
                              check out the other parts..seat frames and all the inside panels also got factory seat
                              cushins and engine support mount for new frame setup
                              • #75
                                Man, it's like Christmas at your place the last two weeks. That is going to be one nice springer. I'm enjoying the updates as you go.
