but does fine otherwise. Anyone have any idea what might be the remedy?
max II does not turn right in reverse
if both sides will pull in reverse, but one side won't stop to make a turn than you have an adjustment problem. if one side won't pull in reverse then it is a drum issue. the post above will help if it's adjustment. if it is a drum issue, this post should cover what the issue is http://www.6x6world.com/forums/trans...se-1-side.htmlA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Thanks for putting me onto the adjustment thread. I've ordered the adjustment tools and await that. Now I see I need to put 15 inch pounds of torque on the plungers, but I can't find an appropriate torque wrench. Can someone put me on the right trail for that?
Frank
