Does anyone know the proper size for the plywood base & what do you suggest I use for the foam & vinyl? What thickness have people been using for the foam? Took a project for a BigMax from rebuild to restoration...$$
Question on seats??
There are two articles in the how-to section that cover seats (pun intended
Make your own ATV Seat
Bronco Seat for your Six Wheeler
Hi:
As a marine guy first and foremost, I look for what works there since water is the common enemy of a lot of materials. Seafoam from Defender is a good closed cell foam (This means it WONT absorb water, even if the cover is ripped and it gets doused, sat on while wet etc...)
(From Defender's Site)
Our popular unicellular flotation foam is non-water absorbent preventing mildew, foul odors and deterioration. A comfortable, semi-firm foam with a buoyancy of approximately 50- lbs./cu. ft. Foam sheets are easily cut with a razor knife for do-it-yourselfers
I plan on using this for a few seats, and when I figure out how much I need/will get, I'll put a post, if a couple of us locally need some, $$$ can be saved since it's sold in 4' X 6' sheets. It's not real soft so it'll absorb shock, not let you sink to nearly the base and then without any cushioning left you'd feel every bump like if soft foam is used. Ride in the bow of a boat in rough water on the stuff and you'll see how good it is (Boats don't have suspension either. And at speed, trust me, Water is HARD
This is the thicknesses that they carry
Closed Cell FoamAttex 295 Wild Wolf: sigpic My Runner
Attex Super Chief - Sold.
