I'm finally getting up enough courage to tackle a bearing change.There certainly are a good number of threads with some great material here on the forum.My Max II has bearing cages and of course solid axles.While I haven't found a lot of specific material regarding change with bearing extensions I am assuming just a third more of the same.Specifically I haven't as yet found material on details of removing the brake assembly on the front axles.
My reason for changing the bearings is it takes on an excessive amount of water and occasionally I hear a snapping sound coming from the front left wheel.When filled with water it leaks excessively around all axles though some more than others.The machine has 240 hours with nearly 100 of them with tracks.None of the recommended bearing checks reveal a problem(play in the wheel/axles).I maintain that the up and down play is much harder to determine unless both outer bearings are worn.
A bearing change looks like a gargantuan task to me but the material here gives me some hope also I would like to be able to do it with a degree of comfort.If I can do a bearing change and have the acquaintance of a good T-20 man,I think I could keep it running indefinitely.
Any tips further to the threads would be appreciated.
