Wonder what it would cost to have someone build this?
Auxiliary transmission for Max T20
well if this is for a max-II using sprocket's and chain? I can mock one up using my max-II as a guide but the question is do you want to still use the original belt and whether or not you want to use gears or sprocket's and chain.
Also if you want a lever or shifting cable or solenoid to activate between HI/LO.
With out that info it would be hard to give an estimate.
Originally posted by greg pinson View PostFREQ42,That is really cool. Exceptionally simple. RI should look at this and put it in production. Harley Davidson type motorcycle transmissions are either 1:1 or a small overdrive around .87:1 in high. 1st gear is 2.94:1 or 3.24:1. I wonder how much it would cost to have a machine shop build this?
Brushcutter, you would have to still run it through the T20 for steering and braking.
I think this could be built in just a couple of hours, once you had all the components gathered up. What will take a lot of time is fabbing up the mount to the machine, frame out ya' know. I wonder if it would sit on my transmission bracing, which wouldn't require the frame to be pulled.
I'll do some looking after work this evening.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
Well I went out today and took sum measurement's and quickly found a problem,
1, I have a OH180 motor but don't know what motor you have?
2, My exhaust is small and out of the way but don't know about yours?
3, If we reuse the original belt it will effect where the input and out put shaft placement will be do to the other two problems, a shorter or longer belt may be required.
I'm not trying to ball-out and I do want to help in any way I can but without sum pictures of the area and more information on your setup I'm afraid I'm building this to fit only my unique machine and may be a night-mare If you tried to install in into yours.
