Is it 15lbs? seems a little soggy to me.. What tire pressure you guys run at? & is there different pressures to run for different terrains?
Whats the proper tire pressure to have on a MAX?
15psi is maxxing out most of these tires. What tires are you running? In general at least, more PSI will swim better, but 1-5 psi is a good starting range. If you have good beadlocks (not true beadlock with locking ring, but with the inner groove to keep the tire from easily de-beading. You can see the groove from the outside ~1" from the outside of the rim.) you should not have de-beading issues at even 1psi, K-locks said to run at under that and hold good.
I run ~6psi on the wolf since I have 4 NONbeadlock rims, but it is a tad rough. If I air down to 2 or 3 it rides nice.Attex 295 Wild Wolf: sigpic My Runner
Attex Super Chief - Sold.
Go to the "Tire and Wheel talk" section of the forum. Search the threads for "sidewall" it came up about 1/2 way down the first page for me. Sorry I can't be of more help with a functional link or something but I'm quite "computer illiterate".
Joe.sigpic
