HID upgrade
  • HID upgrade
    For anybody interested in doing an HID upgrade, I just recently got some KC Hilites 6" replacement fog light lenses (part # 4206) and a KENSUN HID Xenon Conversion Kit H3 6000k. The lens fits perfectly in the headlight retainer ring. The only modification I had to do was slightly bend up the reflector inside the lens because the HID bulb was a bit too long.
    I did run into some electrical issues though, seems like my battery has drained. It could have been from firing up the lights a few times without starting the engine.
    This is what the manufacturer has to saw about power consumption:
    " The gas is ignited with an approximately 23,000 volt charge and stays illuminated by a constant 12v source that is provided by a ballast which is connected directly to your battery. Remarkably, HID lights are able to provide greater light output with much less power consumption. Studies show that a 35 watt HID lamp produces 3 times as much light compared to a 55 watt halogen bulb. Moreover, the 55 watt halogen bulb uses a continuous power draw of 10-15 amps, while the HID system uses 20 amps for starting up, but then drops down to a mere 3 amps during operation (that is up to 80% less power during use!). "
    I have a new Sears Diehard Gold battery and recharding it now. I'll try running the lights again after a full change and see what happens...
    "the 55 watt halogen bulb uses a continuous power draw of 10-15 amps" Yeah right, anybody want to buy some prime agricultural land in Florida.....comes with livestock. The kind with big teeth. lol By definition 1 watt = 1 volt x 1 amp. 12v x 4.6a=55w The High Intensity Discharge probably does produce much more usable light, but nothing else is as efficient as LED.
      I found out my battery drainage issue was due to a faulty regulator...
      I also picked up a two pairs of cheap H3 led's on ebay. One set was a 3528 and another I'm still waiting on are the 5050 led's.
      I'll post pics later for comparison purposes, but can tell you now that you get what you pay for...
        Hmmm...some LED Conversions may be in store for the attex...and i agree, LED"s are the way to go when it comes to being in a rough, tough environment.. My backup light i got wired up is super bright..now if i can find LED headlights, im in!!
          Did you say LED? These are the lights I am running on my hustler rebuild.. https://www.surpluscenter.com/item.a...tname=electric I have 2 in the front mounted on either side of the winch and a single in the back for when I need to back up or see behind me.
            found a KILLER site for HID ligting!!! way cheap.... They have flood, spot and trapizoid, (trapizoid is my favorite, as it is both a spot and flood) and 35 and 55 watt lights!! 100 bucks for a light or 35 for balast and 15 for a bulb!
            HID & LED Lights
            ATV = Alaska Terain Vehicle
              that site also has re-greaseable 1" axle bearings for like 7 bucks a piece... not triple sealed...but still...alot cheaper than most other places that sell that style!
                I changed the bulbs for LED on my MAX.
                as it's not a very high speed machine, I don't need to see very far ahead of the machine, 30 feet is enough.
                with all lights open, it barely draw 1 amp, leaving enough amps for the heated throttle cable and the heater fan.
                2008 MAX-IV 500T 30hp Bandolero
                  Those are some excellent tips and links guys. I have amber LEDs with clear lenses (they look clear when they're off, amber when they're on) for the headlights on my Hustler 980 BIGFOOT and then I have clear 35W halogen driving lights mounted on my factory Hustler bumper/light bar up front. It REALLY lights up those dark trails and doesn't drain the battery at all.
