New Member - Max II Project
  • #16
    hay bjk things are looking up for you then a. couple of things you might try (1) how about a bill of sell from who you bought it from? (2) just take it to the state and tell them you never registered it before cause you only road it on private land then it sat for years now you want to register it and over the years you lost all paper work - called the factory and they no longer can issue anything cause its too old.(3) just take it to them and see what they say and go from there. I think as long as they get their money they just might not care? good luck keep us posted P.S. MSO comes with all atv's and snowmobiles when you buy new from dealer then you take that to the state then with that they issue a title at least that's what they did in Pa. that is where i'm originally from and that's what they did back in the 60's (if i remember right back then they didn't even title things like that but could be wrong "sometimes i am") LOL darn old age I hope this helps you
    • #17
      I am regestering my 1972 Big Max ( same situation as you ) I have MV forms at home, I will get you the form numbers later today.
      • #18
        thanks alot speedycoop... i would greatly appreciate that....
        • #19
          Form's are MV-51,MV-51B,MV-82 probably available online . If you have #40 chain I have a complete set of sprockets . Good luck
          • #20
            thanks again....
            • #21
              first run...still needs some fine adjustments...but damn it sure is fun
              • #22
                Looks great......nice work!
                • #23
                  here is the 72 max II in action for the first time since the partial rebuild
                  https://www.facebook.com/photo.php?v...=2652017948847
                  • #24
                    Just registered my Big Max today. I also needed a bill of sale from previous owner and a weigh slip from a certified scale. Any questions you can call me at 716-863-9040(they asked how long I had owned the machine.....and how long the previous owner had it too. It is better for you when you have had it for a time as opposed to a short time, per DMV lady, for registering) Good Luck !
                    • #25
                      thanks a lot speedy......
                      • #26
                        does anyone know where to find a 3 bolt greaseable housing for the 206-20 bearings ( 1 1/4 x 62mm) .... i have spent hours online looking but can only find 2 and 4 bolt units....i just replaced a bearing on my 72 max II and i dont like that they are not greaseable...i would like to change all 6 outer flanges to greaseable .....or has anyone tried adding grease fittings to their stock flanges?.....or found a sutiable replacement?
                        • #27
                          give buffalo bearing a call. I just got 14 of those flanges from them yesterday. (716) 874-1720
                          • #28
                            got to spend the day in the garage.....
                            -bilge pump installed
                            -framework for top fabed and attached
                            -canvas top attached
                            bring on the snow....!!!!!......now i just need to find or build a set of tracks....
                            • #29
                              Looks good!
                              • #30
                                thanks
