Removing Max II Sub Axle
  • Removing Max II Sub Axle
    Hi there, my sub axle in the rear of the max-ll broke. Now what is the best way to remove what is still in place? I'm having trouble removing the cotter pin and I'm thinking I might have trouble sliding it away from the other axle. Thanks for the help.
    Last edited by Mike; 01-27-2012, 10:04 PM. Reason: moved post to a thread of its own
    I'm not sure what you mean when you say sub axle?
      sub axle
      It's the piece between the axles in thw middle of the machine.
        Oh you mean the stub shaft that the older Max II axles ride on in the middle of the two inner frame rails.
