After calling around the cheapest place to get HC207-20 r3 triple sealed bearings is from Kaman Industrial at $17.10 a piece. Buffalo was close at $17.44. Just thought I would pass this along so people know where to go when you need bearings.
Cheap Bearings
triknologist is right, you will want to run the triple lip sealed bearings. Those single lip bearings that you posted the link to won't last very long in our AATV application."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I've had the best luck buying from www.thebigbearingstore.com . Lower prices and they have a lot of bearings on hand.Everybody dies, but not everybody lives.
There are triple lip sealed beerings that are much better quality than some I know a set I just brought are about $65-$75 a beering I know people that have used these and basically will never have beering problems again .i can buy triple sealed beerings for $25 they are crape 12 months time your replacing them
Origional axle bearings
Not to be difficult but does anyone know what the origional bearings from RI were? I understand how the triple sealed bearings are MUCH better than the less expensive ones. however I have a Max II i bought new in 96 and it is just now in need of bearings for the axles. If the origionals were of the "cheaper" variety I have no qualms about using them again since they lasted me for this long the first time.
Your correct Mike, I just re-bushed and re-bearing-ed my MaxII with the factory bearings. The bearings are made in China but appear to be good quality. Peer is owned
by SKF. as much as I hate purchasing offshore parts there is a limit to how much i will spend on 6 bearings.
i also like to support RI when I can.Acta non verba
