How many RPM's is the motor turning? Is your belt adjusted correctly? A loose belt will do that.
max II with 14 horse
I've been there too brother, and let me tell you that a tiny tach or similar item is worth buying and installing on your machine(s). The Tiny Tach is about $30 and has an hour meter too (good for oil changes and such), knock offs start at like $15 online.Originally posted by ERCELL View PostHave no way of checking rpms the belt i got was th hp 3035 and its a very tight fit.....l like to buy stuff and no I don't do payments!
Years ago I encountered the same issue running hills with the 14 hp Briggs in my Max2. I did the standard checks that everyone mentioned, then lastly checked compression, and one cylinder was significantly weaker than the other. Upon teardown of the engine I noted lots of cylinder wear, as well as ring failure, which struck me as unusual because the engine ran so well on flat land. It did have about 500 hours on the machine at that time, I replaced it with an 18 HP Briggs and never looked back. My only regret is that I didn't go with a 23 HP but the 18 is more than adequate.
