Went for a great ride sunday in southern maine with a few guys. 6 machines all togeather. the next day my throttle lever broke. not the cable but the plastic lever. Any idea where I can get a replacement?
Max 2 throttle lever
The older machines had a plastic base with a plastic lever. The screw that holds the base to the stick often will crack the base allowing it to move. The new units have an aluminum base for the set screw......unfortunately the cable is different, and you can't just buy a new lever, you need a new cable too.
Does this sound like what happened with yours?
I prefer the OE levers, but other people have used gokart levers or bicycle brake levers.
I just bought the new style metal trottle lever and cable from RI, it's about $70 for the two parts. The new cable is shorter and comes with a upgrade kit for the linkage. The cable comes off the front of ther engine instead of going all the way around to the back. You can still get the long cable but the shorter one is much better.WANTED: MAX IV
