Hey Mark, I could not find a fuel pump made by koler. Napa carries one rated from 1.5 to 4psi, will this one work or is there a better choice. Thanks
Cold air intake
yamadog, If you buy an electric fuel pump get one that does not exceed 2PSI, i purchased a 1-4 psi one and now have to install a fuel regulator to get the psi below 2. The current set up floods the engine. Does the napa one have a way to regulate the pressure? Otherwise get in touch with a Kohler dealer and get theirs. The cost will be about the same by the time you pay for a non Kohler fuel pump and regulator.
TinmanSmile, it's only gonna get worse.
I finally got my fuel pump from kohler yesterday. It was a bit pricey, but I figured 25,000 for a bigboy toy why cut a corner on something that makes it go. It looks well built. I got it put on last nite, and I'm headed to the swamp today. I hope this helps hot starts as much as the cold air intake helped power. Are there anymore improvements that I can make to help make a great machine even better. thanks to everyone for their help. God Bless
Took ox out to swamp for test run after changes and it runs like a different machine. Does not seem to loose any power what so ever now. Talked to matt and he said I should go ahead a change the spark plug to a hotter one while I was at it. I was on the road when we talked and I couldn't write it down. Does anyone know what the numbers on the new plug are? Mat if you see this shoot me a email thanks.
It's a Champion RC12YC stock#71. I put a set in my Ox and it helps on starts and it runs better. CougarOriginally posted by yamadog View PostTook ox out to swamp for test run after changes and it runs like a different machine. Does not seem to loose any power what so ever now. Talked to matt and he said I should go ahead a change the spark plug to a hotter one while I was at it. I was on the road when we talked and I couldn't write it down. Does anyone know what the numbers on the new plug are? Mat if you see this shoot me a email thanks.2011 MUDD OX KUBOTA TURBO DIESEL
