Ahh yes hindsight... at least i now know about the MMs. But i doubt i would ever be able to purchase one. I will not have that kind of cash to outlay on amphibious ATVs. My doesn't work like that. We will only ever have enough cash at anyone time to purchase something the price bracket of an Ox. We got very lucky, and received additional cash after the first one was purchased Also the two Oxs were purchased for two different projects so they are to be used differently (one for exploration and the other for heavy work). Additionally where we work, i would never go for one ATV, we must have two just in case. Our hides were saved a few times at the start because we had a second ox that was used to pull the other ATV so i value that, and I am sure we will benefit from having two again in the future.
Some of you guys had asked for an update, so i was just providing one. But we have not exceeded the weight capacity on land despite all the doodahs. If it weren't for those persistent niggles we would be laughing....not saying i'm completely happy, but if i managed to fit a square peg in a round hole, that's not bad...I'm one outboard away from being satisfied....and it is only when it is replaced I will come close to spending what it would cost (2 atvs, all the accessories, modifications and repairs, 3 outboards, a 7 x 20 enclosed cargo trailer (which cost the same to ship as the purchasing price) for one hydratrek (6 x 6) with tracks, a cab and a trailer (and this does not include shipping costs)...and i don't know what would have gone wrong with the other machines and if they would be easy to repair. So despite the headaches, the OX is still the best value for money...
Help my Mudd-Ox sunk!
Forget the hydrotrek look into a Marsh Master made in LA. Not cheap but all the utility companies use them down south and I can tell you they use'm hard on water/land and muck. My .02.........
We explored the dually idea with the tracks, but was advised i would need a set up that could deal with the extra weight at the wheels..so in the end this is the best i could do..it works (for now), so I'll keep milking it until the Ox dies (hopefully a pleasant death)..Originally posted by Buzz View PostIt's too bad, you couldn't run dually's and a set of dually-tracks like Tim's Fat-Cat tracks. I'm sure a set could be made to fit over your 25" tires too. Maybe you already have more tires and dually-adapters? This way you could even remove your outriggers and should have plenty of buoyancy. It would make your p.s.i. on ground much lighter too with nominal increase in wheelbase. Significantly less actually if the outriggers were removed. Hindsight I guess. That would be a great set-up for your application. The ox will do the job very well if it's set up correctly.
Well if i ever have any money to piss down the drain i'd like to try the hyratrek...Originally posted by MaxRules View PostVery interesting use and set up you have on that Ox. It sounds like you are navagating some difficult terrain after your lengthy water journey. I think all that weight you added in pontoons for better floatation in the water is preventing you from being very capable on land. Soft ground and climbing out of banks require the vehicle to be as light as possible. I think you are probably using the Ox in several ways it was never designed for and that thinking is probably confirmed by the huge pontoons and outboard hanging off of it. If a vehicle doesn't fit the user for 100% of his needs, I usually take the time to recommend one that will. In this situation, I don't think any amphib is suited for the need or could do better than the Ox.
Thanks drew..not looking for speed per say just would like to go a bit fast than 1- 2 mph..trimming up the outboard reduces the water coming up on the headlights. I got up to 5 mph with the 70 hp, and it was reasonable, so looking for that..This isn't the ox that sank. But we changed out all the harnesses for it ages ago..
Some red lock tight on that bolt that keeps loosening up should help you out there. Your Ox was sunk in salt water, so you may want to consider replacing your wiring harness. Its actually amazing you have not had or gremlins in your system considering the hurricane incident. As for water plowing up the headlights, I believe this happens when you have achieved maximum hull speed and are providing additional thrust then whats necessary. None of these machines are speed boats or jet ski's. They simply make water and land passage possible at a reasonable rate of speed. I don't believe a more powerful engine will get you going any faster, but maybe one of these really smart engineer guys will chime in on that.
That's a great idea. Far more reasonable than those pontoons and great traction for coming out of steep banks.Originally posted by Buzz View PostIt's too bad, you couldn't run dually's and a set of dually-tracks like Tim's Fat-Cat tracks. I'm sure a set could be made to fit over your 25" tires too. Maybe you already have more tires and dually-adapters? This way you could even remove your outriggers and should have plenty of buoyancy. It would make your p.s.i. on ground much lighter too with nominal increase in wheelbase. Significantly less actually if the outriggers were removed. Hindsight I guess. That would be a great set-up for your application. The ox will do the job very well if it's set up correctly.
What do you and your team actually do over there, what's your job definition / mission?
Very interesting use and set up you have on that Ox. It sounds like you are navagating some difficult terrain after your lengthy water journey. I think all that weight you added in pontoons for better floatation in the water is preventing you from being very capable on land. Soft ground and climbing out of banks require the vehicle to be as light as possible. I think you are probably using the Ox in several ways it was never designed for and that thinking is probably confirmed by the huge pontoons and outboard hanging off of it. If a vehicle doesn't fit the user for 100% of his needs, I usually take the time to recommend one that will. In this situation, I don't think any amphib is suited for the need or could do better than the Ox.Last edited by MaxRules; 05-08-2013, 06:23 PM.
Short term update from the guy with the sunken ox...
Just a quick update and some questions as well. We (my research student and I) have been using one of the two oxs we purchased from Matt. As some of you know, we rigged one with a 70 hp yamaha outboard. This was set up sept./October 2012. Five days after it was set up, the 70 hp was stolen, so I had to use the 25 hp instead. I’ve posted pictures of the ox on the river. It floats well with the set up, but with the 25 hp (high thrust), it takes us 1.5 hrs to 2 hrs to access our sites, compared with 30 - 45 mins for a 14 foot jon boat with a 4 hp two stroker. I hope to replace the stolen outboard with a 60 hp evinrude (it weighs the same as the 25 hp), and I can purchase a 2010 model (brand new) for much less than the 70 or 50 hp yamaha.
I am usually mindful that the ox is one structural failure away from sinking to the bottom. So we usually do our checks before taking it on the river. Also I’ve gotten over the not-for-the-faint-of-heart entry into the water from the riverbank and from the river on to the bank. We have to find a tree close to the bank to winch the atv out of the water in most cases to climb out of the water.
But I can’t say we’ve operated the unit with reckless abandon. The sinking and becoming stuck all too easily muted that attitude. The pullpal works if we can get a good grip. But most of our sites are too soft for the ox. So driving takes some amount of planning (one person scouts for places to drive).
While we have not had any serious mechanical failure, there have been some niggles that need to be constantly straightened out.
We hear the knock (discussed on the forum) while turning. Also some rods that aid with the steering keep coming loose (see next post). So I’m wondering if I should screw them in with some cement like substance. But any hard turns, they come loose and we have to keep screwing them back in.
Also our hand break stopped working (see next post), so this will have to be repaired.
We have disabled both the neutral and hand brake not-starting feature (if you can call it that). We’ve found that when we get stuck, depending on the severity, water can enter and kill the capacitor (?)/fuse that controls the handbrake and the neutral feature. Also when on the river, the atv can build up a wall of water in front which ocmes in through the headlights and where he winch is attached (we’ve tried to seal these with silicone but it doesn’t stop it entirely). So even if the fuse for these blow and the Ox doesn’t start now, we know it’s some other electrical problem. Also we wrap all of the fuses/capacitors under the dash in plastic bags so that these aren’t affected if the atv floods again (see pics).
So has it been worth it? Well we aren’t really confident when we are using the Ox. We are always wondering what will go wrong next. The tracks came off while trying to negotiate a tight turn, the little niggles are persistent, and we've only been out once with the ox and not become stuck. We have decided not to venture too far from water and we take our jon boat with us just in case something goes wrong.
We have accessed some previously inaccessible sites, although we have since walked to the sites through the peat marsh. But as we found out, it can be a difficult walk (my student and I almost had a heat stroke while refitting the tracks in midday heat, so we weren’t aware how hot it can get in the open when we are not using the ox, and he almost passed while walking through the peat at 5 in the afternoon!) and the mudd-ox made light work of it. Most significantly, where we are working is like a weed (marijuana) factory, and we had to use the ox to negotiate the weed beds. Also to build the beds, trenches are dug around an area that is piled high (no pun intended) with peat, and the weed is planted on top. So old beds are surrounded by these bottomless trenches. The ox makes light work of them (they are narrow enough for it to cross them and climb up and over the weed bed). But when we are walking through the marsh we can’t see them, and we have fallen in them while walking. Also if we try to jump over them, we have a narrow strip to aim for. So in that regard the Ox has helped us out.
The really heavy lifting starts in a couple of weeks, when we have to use the ox to cut some invasive plants, and we have to conduct a habitat wide survey with the ox. So I’ll let you know how it performs at that time..
Kmac
IMG-20130312-00128.jpgIMG-20130312-00130.jpgIMG-20130312-00131.jpgIMG-20130312-00110.jpgIMG-20130312-00109.jpg
I'm new to this butI had a chance to ride in a mudd-ox this weekend with Matt, and was totally amazed with its preformance, the ability of the machine to go places it did was awesome ,it was nasty muddy slick ,and the hills it climbed and desended with out spinning the tires losing traction was something in itself. I think it put alot of machines to shame but everyone uses them in different ways so it preference, myself I like to trail ride and have no need for speed and it can carry the family and gear to camp out on the trails, if things work out for me I will be a mudd-ox owner one day, thanks Matt for the ride
Kmac: Thank you for the status updates. The grading system you assigned makes perfect sense to me. Most manufacturers request feedback from their customers, and I think this has been clearly stated in the thread. I am certainly happy that most of your problems are behind you at this point.
I sincerely hope the customer service issues get fixed with Mudd Ox. I think its a very good off-road machine, and the hydraulic drive is the main advantage over the competition, at the moment. Maybe with a few improvements in flotaion, balance, free-board, etc., it could evolve into the machine to beat.
Please keep us posted on the status of your machines, and how the eco-tourism business goes.
