so i really got to take the thing in some light mud and water.. man this thing is fun.. 382168_443864729007961_864601412_n.jpg
then i broke an axle.... was able to quick repair it and get back riding in about an hour.. 248895_443864589007975_1959464019_n.jpg
drilled a new hole down the shaft a little.. lucky i broke it near the inside holding bolt...
now that axle keeps breaking the bolt at the hub.. i already fixed a front one from doing this but that took drilling it out slightly bigger
i think its time to pull it apart and put new bearings and axles and chains.. all the wear out parts...
so im wondering should i keep with a solid axle or go with a good thick hollow axle? i know hollow is normally stronger but are they in this app?
also what kind of bearings am i gonna need? are they a normal sealed bearing.
and where can i get good strong chain and about how much does it take??
thanks!
thanks!
