Homemade 6x6 with 3 cylinder motor
  • Homemade 6x6 with 3 cylinder motor
    hi guys i thought i would have a go at making an amphibious 6x6 using a car motor and 6 wheels off a 4wheeldrive
    Last edited by Mike; 01-25-2013, 04:00 PM. Reason: moved thread from Argo forum to Other AATV forums
    Kevin,
    Sounds like fun, you should do a search for "3 cylinder " or "home made " on this forum and see what pops up. There are a couple projects like that on here.
      yer should be i started on the frame today i will upload some pics soon
        Here are some pics of todays work
          Good start...I'm excited to see what you end up with !
          Please keep us posted with the progress :-)
          Tim
            You're not wasting any time on this project! So far so good.
              It's a great start. I think I'd make it a straight track machine and build in some floats in the center of the tracks to help with stability. Good luck on the build.
                That engine looks heavy!
                Weight distribution will be important when you float it.
                I would mount it ahead of the rear axle for sure.
                  Are you using the transmission/transaxle that's on the engine now? If so, looks like you could shift it towards the middle and power the center axle and chain to the outter axles thus evening out the weight distribution.
                  Thomas
                  94 MAX IV, 16 Vanguard, Aqua Torques, 1 1/4" wheel spacers
                    hi guys were the motor is sitting is going to be the front and i will be sitting back from the middle the reason i want the motor at the front is for climbing hills but i guess if it was in the middle it would be even as far as desending hills and floating.
                    The motor is a front wheel drive daihatsu charade.
                      i tested the position of the motor and how it would efect the way it will float i made a quick raft out of 20 liter drums so it had roughly the same surface erea on bottom it was fairly nose heavy but it will do making it float is an extra at the moment but im shore it will be done and also im it wont be used in alot in water anyway
                        Todays work
                        [IMG][/IMG]
                        [IMG][/IMG]
                        [IMG][/IMG]
                          finished making all the shafts and the hubs it is now standing on its own just have to wait for sprockets and chain then i can give it a test but their is still lots to do like wire up the motor install seats and steering wheel and peddels and floor ecetra excetra
                            wheels on seats mounted as well as steering wheel and pedals also tackeled the wiring today wich was one hell of a headacke!
                            [IMG][/IMG]
                            [IMG][/IMG]
                            [IMG][/IMG]
                              I bet you'll be able to fit 31" tires on there! I'm thinking these Goodyear 31x15.50x15 tires would work nicely.
                              Industrial Magic
