I think I'd look for another belt that will work. You can take some measurements of the distance between your CVTs and give Roy at Quality Drive a call: Quality Drive Systems He will be able to find the closest belt that would work for you.
StarCraft
Thank you Mike
I Do have a Napa Belt book for the atv & snow Moble And thy list the Rec in there along with Attex and Hustler ? And I have a New Gates belt But I can return it unless someone here need it ( I get a real good deal through work !)
I just didn't realize how BIG this kohler was till I got it mocked up.
PLus if I can sell it I will put a 22hp Pred engine in it.
Also I need a Cltuch for a 1.1/8" crank and that alone is over half the price of the 22 pred
And at this stage I can go ether direction
As always I am open to input guys
Well I got m new clutch today and a new longer belt so Saturday after work is m test fit time. I am Hoping I can fit the Kohler in there ?
I have a 1" aluminum plate to mount it to so location is key. I will get pic's of the progress as it develops . Anyone know of Upgrades you can do to a Kohler 18 ?
Will keep you all posted
I don't think fitting the Kohler will be a huge problem. Mine has a Kohler 25 in it and it really doesn't look like the "fabricator" went to a lot of trouble to make things fit together, if you know what I mean.Stuck in the seventies- not in the swamp.
How many machines do you have?Originally posted by Don View PostI don't think fitting the Kohler will be a huge problem. Mine has a Kohler 25 in it and it really doesn't look like the "fabricator" went to a lot of trouble to make things fit together, if you know what I mean."Racing is life. Anything that happens before or after is just waiting."
The ones that allowed to be publicly known are right there on top of you.Originally posted by smudvapor View PostHow many machines do you have?sigpic
Well It's in there
I redid the adjusters (Tranny) and put the clutch on the engine. Had to cut about 1/4" off the crank.
I made a spacer also so the crank is good to go. Just a NOTE : The Duster Clutch is Only bored and keyed 1.1/4" inside so it will NOT slide all the way on the crank like the Salsbury style clutch
So anyway here is what I have so far. Let me know what you think ?
Got the Split Shift made and happy with it . The rods had to have some Funky bends in them due to the floor pan configuration in this machine. But all in all it should be a cool upgrade. Just playing with shifter Knobs now ? Real won't know what works till I get it all in the body with the floor pan ??shift.jpgshift1.jpg
