I Have A Max Ii (running At This Time, Thank Heaven) And A New (to Me) Terra Tiger, Allis Chalmers Tt-10. The Tiger Has A Big Problem With The Front Left Sprocket. It Is Not Hooked Up To The Left Front Wheel And I Can't Figure Out How To Connect The Sprocket To The Axle. Axle Turns, Wheel Doesn't. The 6 X 6 Came With A Blurry Owners Manual And No Other Information. A Really Good Diagram Of How The Axle In Front Should Look With The Chains, Etc Would Be Of Enormous Help. A Wiring Diagram Would Be Nice Also. I Need To Find A Service Manual And Parts Manual, If They Made One For This Machine. I Think It Is A 1970 As It Is Green, Not Orange Like The First Year Was. I Would Appreciate Any Help Any One Could Give Me. I Have Been Watching This Site For A Long Time And Have Found All My Questions On Atvs Answered Except This One. Thanks,
Chuck
Chuck
). farmtoybuilder should chime in any time now on this one
They drive with a solid pin with external groves. 5/16 X 2" grove pin. But you may also have worn out axle and sprocket. As holes in them get loose- long gated- and allow the pin to come out or shears it off and falls out. You can try new pin in it. If it does drive in tight, you'll have to decide which way you want to fix it. Temporary or to last. Temporarily we have used grade 5 or grade 8 bolt and nut to replace pin. You need to cut excess treads off just a smuge above nut. Then install, tighten and center punch end treads to secure nut. Another option if not to worn is to drill them out over size and put larger metric pin or bolt in them. Or you can remove axle and sprocket to have them welded up and re drill holes. Axle's can be made or brought. Route 6X6 has some weld on blocks to repair sprocket with also. Or you can make some. Any questions email or call. And we can help you out!
I broke the front left axle on my hustler....twice, so I am just a little bit familiar with that sprocket/inner axle does but wheel doesn't thing.
, the broken axle syndrome went away
