Tips for replacing the bearings for the steering clutches on the primary drive shaft.
I think the the replacement of the steering clutch bearings is a critical maintenance task on Terra Tigers. I have torn down 4 drive shafts and removing the bearing housing from the male portion of the steering clutch was a difficult task. Keep in mind, that all of mine were all rusty basket cases, so this is a "worst-case scenario".
Before I begin, let me explain that for the life of me, I can not find any purpose for the second bearing in the housing (the one closest to the driven clutch) except as a spacer. I didn't realize this until after I bought all new bearings, but there is no reason that you couldn't use one of your old bearings to fill the space that this bearing does. Even when fully engaged / disengaged, the shaft on the male portion of the steering clutch (#7) does not slide in and out of this bearing. Nevertheless, you still need SOMETHING in that space because that is what the springs press up against. So save yourself a few dollars and use your old bearing (even if it is shot) in place of that inside bearing. The outside bearing slides over the shaft on the male portion of the steering clutch and gets sandwiched between two snap rings - this bearing is critical.
The task of removing the bearing housing from the male portion of the steering clutch assembly (#7) was a difficult task on all 8 that I replaced. Once removed from the shaft itself, the #7 and #16 are essentially one assembly, but they must be seperated in order to replace the bearing.
The first step is to get out your snap ring pliers and remove the snap ring that is between the bearings inside the housing. Once it is out of its' slot, use a needle nose pliers and pull it out. This will require some effort and will almost certainly result in the sacrifice of the snap ring itself. But it is nearly impossible to take these apart with that snap ring in the picture. So get rid of it.
Next, find a socket that is roughly the same diameter as the round edge of the male portion of the steering clutch (#7). Your socket will also need to be skinny enough to fit loosely between the inner races of the bearings that are currently sandwhiched in the housing (#16). For me, it was an 11/16" deep socket.
Then, hold the whole assembly between your fingers like the Mork and Mindy handshake. Rememver "nanu-nanu"? The housing (#16) will be facing up and above your fingers. The male portion of the steering clutch (#7) will be facing down and under your hand. With the socket resting on the surface of the steering clutch shaft, between the bearings and sticking above the top of outside (now top) bearing....start beating the snot out of the socket. The male portion of the steering clutch (#7) will eventually break free from the bearing housing and fall to the floor. You can then press out the bearings and bearing spacer.
Before reassembling, use a dremel tool and clean up the edge of the shaft on the steering clutch shaft (the one that just took a beating). Then press in your new bearing. Before you press the bearing spacer and second spacer in, you need to reassemble the housing and the male portion of the steering clutch. You will now need to find a socket that is big enough to slide OVER the lip edge of the steering clutch shaft yet still rest on the inner race of your bearing. Pounf the bearing and housing down over the shaft until it butts up to the snap ring. You will now be able to replace the second snap ring (the one you sacrificed). Then press on the bearing spacer and the second (inside and useless) bearing.
Voila, you are done. You might check to make sure that the brass/bronze bushings inside the steering clutch half are still good, but other than that, just slip the whole assembly over the drive shaft and make sure it spins very freely.
